Over the past year, i have spent some time modifying my car. I have focused on suspension rather than power. Now that i have everything that i wanted together, the car feels good, but not amazing. I'll explain...
- First things first. I have read a lot about alignment over the past year. I have also had a couple of alignments. Everything felt great until the new wheels were put on. The steering now has little feel, delayed turn in and has a small dead spot when centred. Ill write the specs of my current set up down a little further. I understand that after putting on wider and lower offset wheels that the cars handling will change, but not this much.
- The car seems to have quite a bit of scuttle and shake when going over anything less than smooth, this can be quite unnerving mid corner, It almost feels like the suspension towers are doing a little dance, possibly somewhat corrected by a strut brace...? I would expect a little of this from a car that has been stiffened so much, maybe i have made it a little too stiff?
- It loves wide open corners and grips till the cows come home, however i have noticed that it does not like groups of tight corners as much (I'm using a tight sector of a road near port campbell near the GOR as an example). It has a tendency to understeer, it also feels a little delayed and quite unsettled when changing directions quickly. Don't get me wrong, it still turns well, but not as well as it should.
My alignment specs are:
Front:
5 Degrees of Castor
2.4 Degrees Neg Camber
1.6mm Total Toe In
Rear:
2.2 Degrees Neg Camber
2mm Total Toe In
I have a 1990 NA6. It has done 209,000kms and has the following mods:
- Koni Yellow Adjustable Shocks, If 1 is Softest and 10 is Hardest, Front is on 7.5 and rear is on 7.
- King Springs
- Flyin Miata Adjustable Sway Bars (23mm Front and 16mm Rear) Front is set to Hardest and rear is set to Medium
- Racing Beat Length Adjustable Sway Bar End Links
- Cusco 4 Point Front Subframe Brace
- Cusco 2 Point Rear Subframe Brace
- 949 Racing 6UL 15x8 +36
- 205/50/15 Bridgestone Potenza RE002 Running at 36psi
- Brown Davis Steel Roll Bar
I can provide more info if needed, i know that some of you are running similar set ups to me and i would be curious to know what works? I drive the car daily but like to have fun with it within reason. The occasional track day will be considered as well.
Thanks a lot for reading and i look forward to some suggestions
