Battery care
Technical Guides primarily to do with the NB series
Silvia
Battery care
Postby Silvia » Thu Dec 08, 2011 5:14 pm
My handbook says the battery in my new 2002 is not a maintenance free one. Do I need to haul it out, or get into the boot occasionally to check it?
Are there any other things to look out for?
I've been using a battery life extender fluid instead of battery water in other cars, with good results, should I use it here if top ups are needed?
Silver Nomad
2002 NB8C
taminga16
Re: Battery care
Postby taminga16 » Thu Dec 08, 2011 8:10 pm
Hi,
There is a possibility that the battery has been replaced, it will not hurt to get it out , make sure that it is the correct type of battery, check that the tray and the terminals are clean and that the bracket is functioning, check the venting system to ensure that it is working properly (if you are uncertain about this then speak with someone who will know what is required) put it all back together and give the terminals a wipe of Vaseline then and go for a drive :) .
Cheers.
Greg.
Return to “NB [1998 - 2005]”
