Sancho's nb8c
sanchodotdj
Re: Sancho's nb8c
Postby sanchodotdj » Sat Jan 07, 2012 5:20 am
xxr's are on their way to my place hopefully in the next week or so.
i masked them so there is still a ring of amber when it flashes, and i used tint spray so you can still see them flash.
yes i used an oven, 150degrees for ten minutes (then used high temp paint)
i added a bead of silicone all the way around when resealing and they seem to seal fine
sanchodotdj
Re: Sancho's nb8c
Postby sanchodotdj » Mon Jan 30, 2012 3:38 am
Re: Sancho's nb8c
Postby Lokiel » Mon Jan 30, 2012 11:39 am
The black headlight surrounds look great on a black car - billybunter painted his white to match his newly-painted white SE and it just looked like "too much white" - maybe if they were painted black the contrast would have looked better?
I suspect that your side indicators may be deemed "too dark" by the "blue boys" - they do look good though.
I bought a set of clear indicators and gave them 2 coats of VHT Niteshades to tone them down a bit - I didn't want to tempt fate by going any darker:
BEFORE:
AFTER:
slimx
Re: Sancho's nb8c
Postby slimx » Mon Jan 30, 2012 4:09 pm
Looks great!
It looks like the wheels are flush with the guard, doesnt ever scrub?
Thought of an Air Splitter?
They make it for nb8b/c without the SE lip too dw, its like $180 or so.. though
sanchodotdj
Re: Sancho's nb8c
Postby sanchodotdj » Mon Jan 30, 2012 11:22 pm
Doesn't scrub at all. But its very low to the ground to speedbumps hurt!
I'm going to make custom splitters all around cos I'm a tightass and I like doing things myself lol
Hjt
Re: Sancho's nb8c
Postby Hjt » Tue Jan 31, 2012 11:52 pm
Busted!
Hjt
Re: Sancho's nb8c
Postby Hjt » Tue Jan 31, 2012 11:54 pm
Car looks great BTW. Nice alignment
Hjt
Re: Sancho's nb8c
Postby Hjt » Tue Jan 31, 2012 11:58 pm
http://img600.imageshack.us/img600/7001/dsc0729o.jpg
Just curious, if you have not done guard work to make the wheels fit... don't you bottom out over bumps?
sanchodotdj
Re: Sancho's nb8c
Postby sanchodotdj » Thu Feb 02, 2012 1:27 am
my alignment is way out lolz! will be getting done this week,
thats the only time the car got dríven
i rolled all 4 guards with a heat gun and rubber mallet
i will be raising the front a tiny bit as it does bottom out on humps but drives better than i expected actually
elitee
Re: Sancho's nb8c
Postby elitee » Thu Feb 02, 2012 1:27 pm
Just need more angle going over bumps shouldn't be bottoming out at that height
needs more lows
Users browsing this forum: Google [Bot] and 14 guests
