GoPro Hero roll bar mount - Cams approved?
New South Wales and Canberra Motorsport
Sailor
Re: GoPro Hero roll bar mount - Cams approved?
Postby Sailor » Tue Dec 04, 2012 11:02 am
Just spoke Andrew Thomas (Motor Sport Co-ordinator (Technical)) regarding the camera mounts.
His opinion is that it’s up to the chief scrutineer BUT he allows windscreen mounts providing the suction cap has not yellowed and that in most cases a secondary restraint is provided.
I “made his day” when I mentioned that even Etags were required to be removed at our level. He'd "never heard that one before".
CAMS has no current guidelines and they were, in his opinion, removed to ALLOW the newer suction mounts at the discretion of the chief scrut.
Technology is moving so fast that CAMS is unable to keep up.
He suggested that guidelines should be included in all sup regs to clarify for each event or series
He mentioned that each state seems to police the fitting of cameras differently.
Rob
Hjt
Postby Hjt » Tue Dec 04, 2012 11:14 am
Did the orders on Sunday come from the chief scrut?
david_syd_au
Postby david_syd_au » Tue Dec 04, 2012 11:27 am
Hjt wrote:Did the orders on Sunday come from the chief scrut?
Suggest we wait and see the feedback from the club about events on Sunday, and the issues that were raised.
2011 NC LE "Black Beauty" (ours) | 2006 NC race car "Shazza" (his) | 1998 JDM NB race car "OMG" (hers) | NC Trailer
mazmad
Postby mazmad » Tue Dec 04, 2012 11:50 am
For mine... although suction mounts are the easiest to use I think they are right to ban them. Only takes a greasy windscreen, or worse a windscreen which gets broken on track and you have an object flying around the inside of the car.
Hjt
Postby Hjt » Tue Dec 04, 2012 12:23 pm
Thanks for the imput. As mentioned above ill leave it for others to address.
Sailor
Postby Sailor » Tue Dec 04, 2012 1:19 pm
C of C supported the decision.
C of C is the top dog on the day.
We need only clarification for future events.
Rob
tbro
Postby tbro » Tue Dec 04, 2012 3:11 pm
tbro
Postby tbro » Tue Dec 04, 2012 3:12 pm
david_syd_au
Postby david_syd_au » Tue Dec 04, 2012 4:29 pm
tbro wrote:http://www.rennenmetal.com/proddetail.asp?prod=1008
So good, it's worth mentioning twice! :-)
If that mount meets the rules or guidance from the club, it could be worth a group buy.
Amx5
Postby Amx5 » Tue Dec 04, 2012 6:42 pm
if that mount has a gopro adapter.. it's definitely a winner.
rossint
Postby rossint » Tue Dec 04, 2012 10:53 pm
You can get a tripod mount for the gopro.
Amx5
Postby Amx5 » Wed Dec 05, 2012 6:01 am
The tripod mount listed before will definitely work?
Blesif
Postby Blesif » Mon Dec 10, 2012 5:57 pm
We had our performance box removed. It is designed with a triple suction cap mount for attaching to windscreens and is commonly used that way o'seas without any issue. The suction mounts have never looked like failing on ours nor on others used within the club to my knowledge. The unit needs to receive a satellite signal so windscreen mounting is desirible. It does come with an external ariel so could be mounted elsewhere with metal circlips or clamps but unfortunately the shape of the unit does not lend itself to this. It is a fantastic tool and represents a significant investment. I hope this issue can be resolved.
mazmad
Postby mazmad » Mon Dec 10, 2012 7:50 pm
There are a lot of p-boxes in use in Australia. And agreed under normal circumstances the suction mounts are pretty solid.
I think the point is....when things go wrong there is a good chance it will be flying around the cabin. That is what they are looking to prevent. If you get shunted, or worse roll..... very unlikely but better safe than sorry. Same thinking as applies to seat belt use.
Amx5
Postby Amx5 » Thu Jan 17, 2013 6:49 am
I brought myself a pmd roll bar mount
http://www.pmdraceproducts.com/home/
I ended up with a spare one. I'm bringing it to wakefield if anyone wants to buy it. You need to buy a tripod attachment for it though.
