Semis for 1hr races
ansellpa
Semis for 1hr races
Postby ansellpa » Fri Dec 21, 2012 4:22 pm
http://www.ebay.com.au/itm/215-45-17-HA ... 2c6a1d4e98
These are a really good price.
Has anyone had any experience with these on an MX-5?
Was thinking of getting a hard set for 1hr races?
What compound of other semis do folks use for 1hr racing? talking 2f here
ansellpa
Re: Semis for 1hr races
Postby ansellpa » Fri Dec 21, 2012 9:58 pm
Vs R888?vs v700
mazmad
Postby mazmad » Sat Dec 22, 2012 5:55 am
R888s mediums cost $240 I think for 205/50/15s I would guess these would do a 1 hr easily with the use I have had on them.
bensale
Postby bensale » Sat Dec 22, 2012 9:19 am
Don't think too many people are running the Hankooks on MX-5s...
From what I've heard V700s are better than the Hankooks on lighter cars, reverse if the car is over 1000kg. Both these tyres are in a different league to 888s.
If you get the Hankooks the mediums are a really good compound and don't have any less grip than the softs, just take a bit longer to warm up. Keep hearing good things about Yokohama AO50s and most of the top Tarmac Rally people run Dunlop 03Gs
My next set is some SOFT Federal FZ201s. Got them fitted and the sidewall is so hard the tyre fitter said they're the most difficult tyre he's ever fitted including all of the above. Good start :)
www.othersideproductions.com
ansellpa
Postby ansellpa » Sat Dec 22, 2012 9:35 am
Thanks for the info, I have used federal fz201 and ao50 in medium on a 1400kg car, and r888 and dunlops on a 1100 kg front wheel drive car.
Dunlops are good but even in mediums just don't last.
R888 are not as grippy but indestructible
Fz201 are good value and keep on giving even when they are worn out. Had a set on my evo. And yes you are right about the sidewall. Ao50 much better but expensive.
I don't think my nc will be under 1000kg, running 225/45/17, so I am after any specific info for tyres for this car
Seems like the kuhmo is the best bang for buck?
mazmad
Postby mazmad » Sat Dec 22, 2012 11:46 am
A050s apparently are great but 300+
ansellpa
Postby ansellpa » Sat Dec 22, 2012 12:38 pm
Think they are close to $500 in 17s
Nasty!
But if that is the price of being competitive...
Charlie Brown
Postby Charlie Brown » Sun Dec 23, 2012 7:48 am
ansellpa wrote:Think they are close to $500 in 17s
Nasty!
One of the reasons I run 16s not 17s :wink:
V70a's will last you the hour but the Yokies will last longer and cost more for around the same performance.
But why are you going to run R specs rather than slicks? 1 hour rules?
ansellpa
Postby ansellpa » Sun Dec 23, 2012 10:59 am
I am not all that familiar with the rules.
But car will be 2f, I presume the run R spec?
BLU-125
Postby BLU-125 » Fri Jan 18, 2013 9:15 pm
All the manufacturers are getting involved. NanKang have prod race tyres on the water. Quite a bit cheaper than Federals.......... Have ordered 195/50R15s to test..... ;)
ansellpa
Postby ansellpa » Fri Jan 18, 2013 10:05 pm
There are always bargains out there.
Just got to spend a bit to take a risk on some cheap ones.
Would you give it a go?
Price of top end track rubber is pretty high compared to overseas
MattR
Postby MattR » Fri Jan 18, 2013 10:06 pm
If you run slicks then in the one hour yoou end up in the quicker classes, I think class C from memory. Staying 2F you run with the other 2F cars and most of the semis will do the hour easily.
Just be careful to make sure the tyres are on the CAMS pproduction tyre list before you throw your hard earned at them.
Cal
Postby Cal » Fri Feb 15, 2013 12:33 pm
Have a look at Nitto's too.
ansellpa
Postby ansellpa » Fri Feb 15, 2013 8:06 pm
Have you used them?
seems to be lots of cheap options lately
M1474
Vehicle: ND - Turbo
Postby M1474 » Fri Feb 15, 2013 9:37 pm
Have you priced Achilles?
GHETTOCET
Return to “MX5 Motor Sport”
