The carbon fibre time attack/superlap MX5 NB twins blog
Hjt
Re: The carbon fibre time attack/superlap MX5 NB twins blog
Postby Hjt » Fri Jan 11, 2013 4:16 pm
first set of 15x10 in Australia? They look fantastic. Any idea on the tyre you will run? Hoosier?
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
Postby lightyear » Fri Jan 11, 2013 6:12 pm
These are not the first. Maybe first shipment. And last for the foreseeable future.
I can get 275 Hoosiers, or 245 avons. Might just get some R6 Hoosiers first. Depends on the time attack rules. I know they are not on the list from last year.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Jan 11, 2013 6:28 pm
apparently the avons are way too soft. what about 235 50 r888's?
lightyear
Infinity & Beyond
Postby lightyear » Fri Jan 11, 2013 9:57 pm
The 235/50/15 would be good if I want it to look like a 4wd. They would be pretty tall.
xatz
Postby xatz » Sun Jan 13, 2013 10:17 pm
According to their facebook page the World Time Attack Challenge rules for 2013 will be out tomorrow. Is this the event you are targeting?
JD
lightyear
Infinity & Beyond
Postby lightyear » Mon Jan 14, 2013 8:24 am
Well I was, hoping the car will be competitive enough to enter.
bensale
Postby bensale » Mon Jan 14, 2013 10:11 am
Sounds like you need to be buying yourself some Yokohamas if you want to play at Time Attack now......
www.othersideproductions.com
Postby orx626 » Mon Jan 14, 2013 10:27 am
bensale wrote:Sounds like you need to be buying yourself some Yokohamas if you want to play at Time Attack now......
Yeah Ben....without that rule there wasn't going to be a WTAC 2013 event.
bensale
Postby bensale » Mon Jan 14, 2013 1:13 pm
It's a pity.. While it does help create a level playing field undoubtably it was based around the continuing profitability of the event not the sporting factor.. But if faced with either a control tyre event or the major sponsor and huge supporter of the sport pulling out and no event you'd always pick running the event..
But I'm not a fan of control tyres in any motor sport, particularly this kind of level where there is relevance to the consumer. F1 tyres have no relevance to what you or I can buy... But here it added another layer with relevance to the punter.. Last year it was interesting to see Yokohamas, Hankooks, Dunlops, Bridgestones, Toyos and Federals all competing. In Dave's case if he wants to run at time attack using 15s there is no size choice other than a 205/50/15 or a 225/50/15 and nothing wider than 225 until go up to 17s...
lightyear
Infinity & Beyond
Postby lightyear » Mon Jan 14, 2013 9:06 pm
I will have to work out what to do with tyres. Everything is going to be too tall no matter if I do 15 or 17 inch.
lightyear
Infinity & Beyond
Postby lightyear » Mon Jan 14, 2013 9:41 pm
Looks like the only option is to run the 225/50/15. I am going to get some 2nd hand ones shortly and see how they fit on the 10's. Otherwise i will use the 9's.
I will still buy some 275 hoosiers for track days to give them a try.
tobias
Postby tobias » Tue Jan 15, 2013 9:11 am
I have some 225/45/15 your welcome to try but might no be of any relevance, kumho semis
lightyear
Infinity & Beyond
Postby lightyear » Sat Jan 19, 2013 9:50 pm
I have put the red car back to near stock. It just has the B.C coilovers, front swaybar, exhaust. And the compulsory seat, harness and rollbar. Also gave it a full service, all fluids, mazda speed engine mounts, etc. And it has only just had the brake rotors and pads done last time. So it is all set to enter standard class in victorian super sprint, and modified in the mx5 club vic.
Hjt
Postby Hjt » Sat Jan 19, 2013 10:56 pm
I'm loving your new trailer. Is it Victorian made?
lightyear
Infinity & Beyond
Postby lightyear » Sun Jan 20, 2013 6:40 am
They come from bris. It's like a nevco. Drops down almost flat.
Users browsing this forum: No registered users and 27 guests
