timk makes up for talent with an EFR
- Suspense
Re: saboteur's NB
^ Get RaceChrono on Android.
- zero00
Re: saboteur's NB
mx5002 wrote:sounds good,
i wonder if they have an android equivalent.
Not sure, but google 'Harrys Lap Timer' and have a look - beauty is that you can also look up others lap times so long as they had it running - I think it was $19.99 to purchase
Roger D-SUNSHINE COAST
- timk
Re: saboteur's NB
gslender wrote:Looks good... What ecu do you run?
Thanks Grant, I'm using the stock ECU reverse engineered and dyno tuned by Lachlan Riddel. The results are pretty impressive!
- gslender
Re: saboteur's NB
timk wrote:gslender wrote:Looks good... What ecu do you run?
I take it you go back for any further modification/change to the engine? Overall, how has the cost compared?
Also, what logging or gauges do you have with that?
G
- timk
Re: saboteur's NB
gslender wrote:I take it you go back for any further modification/change to the engine? Overall, how has the cost compared?
If it was something fairly substantial then yes it would require a retune, not unlike any other ECU. It is however based on flow instead of pressure so it can deal with small changes a little more intelligently than MAP based systems.
I'm a little confused about the cost comparison? Do you mean compared to my previous cars running stand alones?
gslender wrote:Also, what logging or gauges do you have with that?
It has a k-line serial interface but it doesn't seem to follow ISO9141. The later model MX-5s can use an OBD2 interface to grab data.
- timk
Re: saboteur's NB
The oil cooler is here and mounted up, just waiting on a new sandwich plate for it before the lines are made up:
I have the Mocal sandwich plate but I wanted to keep the remote oil filter location, so MX-5 Plus are sourcing a GReddy/GREX remote oil filter mount with built-in thermostat.
- TieNN89
Re: saboteur's NB
YAY more go fast bits
I miss the oil relocation kit
it was the best thing ever IMO
- MINX
Re: saboteur's NB
Tim
Where is it going to be mounted?
- Vehicle: NA6 - Turbo
Re: saboteur's NB
clean setup you have, what sort of oil pressure you seeing on the track with the VVt pump?
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
- timk
Re: saboteur's NB
Stu, it's using the Flyin' Miata brackets so it mounts on the steering rack. Here's a pic with it all mounted:
Jason at MX-5 Plus made up the -10 lines for me, I didn't use the FM -8 ones. I'm using a GREX thermostat sandwich plate as it has provisions for my oil temp and pressure senders.
- MINX
Re: saboteur's NB
Are you leaving the oem splash guard on?
How will it get ventilated ?
I have a cutout in my splash guard - dunno if it helps
Re: saboteur's NB
Consensus on MT.net is that it needs ducting to be effective - FM even recommend it.
- timk
Re: saboteur's NB
I haven't ducted mine but it sits a lot more upright than your one Stu. The next track day will dictate if I add ducting or not!
- timk
Re: saboteur's NB
Got some new shoes for street use, I was going to go for KU31 tyres but the price of the RE002 was right so giving them a go:
- MINX
Re: saboteur's NB
mmmmmmmmmm chunky
