Car scissor lift - anyone know anything about these?
yertimer
Postby yertimer » Fri Jan 17, 2014 1:00 pm
Hi
Saw this on eBay
Apparently a new release and Australian made by hero auto hoists Australia
Anyone know anything about them?
Better than a car Jack but not as good or as expensive as a hoist - but could be ok for those of us with small garages.
What do people think?
http://www.ebay.com.au/itm/Self-Powered ... d03&_uhb=1
http://www.carliftaustralia.com/ebay/li ... r_Lift.pdf
NA8 94 Clubman
yertimer
Re: Car scissor lift - anyone know anything about these?
Postby yertimer » Fri Jan 17, 2014 1:11 pm
Sorry this might be under the wrong topic heading ?
NA8 94 Clubman
rossint
Postby rossint » Fri Jan 17, 2014 1:37 pm
I've been looking for something like this as well, Ezcar looks really good but getting it to Australia would be expensive.
http://www.ezcarlift.com
The Hero one says you can lift all 4 wheels off the ground but most of the pics show either front of back in the air so I wasn't sure if you could lock the angle of the platform.
I'd love to hear from someone who has used one before.
bigmaxy
Postby bigmaxy » Fri Jan 17, 2014 1:51 pm
I'm very keen to put a lift in when I build the new house. Am thinking of a scissor lift so was very interested to see this topic.
Not sure these are what I'm looking for. Appears a wee bit flimsy for my liking and I'd want some extra assurance before I climbed underneath and started reefing on things.
Personally I'd also rather something that I can go from one end of the car to the other. Even if I do have to go over a small bump for hydraulics or cabling.
Thanks for the link though.
yertimer
Postby yertimer » Fri Jan 17, 2014 2:18 pm
The Ezcar lift does look more sturdy, but you are right getting it to Australia might be expensive.
I travel to the US a couple of times each year, but at 60kgs or 70kgs per unit, I don't think that helps much.
NA8 94 Clubman
deviant
Postby deviant » Fri Jan 17, 2014 4:06 pm
bigmaxy wrote:I'm very keen to put a lift in when I build the new house. Am thinking of a scissor lift so was very interested to see this topic.
Yeah I would not really fancy really doing heavy work on the car on this hoist, looks fine for doing oil changes and swapping wheels over and the like.
When you build just get the floor of your garage appropriately reinforced and buy a proper two post lift, really easy to find second hand for $1500 or so.
Postby Lokiel » Fri Jan 17, 2014 4:21 pm
yertimer wrote:The Ezcar lift does look more sturdy, but you are right getting it to Australia might be expensive.
That's the one I decided was probably the best but cost + S&H is prohibitive :(
Maybe we can convince NitroDann to knock up something similar - they'd come in handy when installing his exhausts.
yertimer
Postby yertimer » Fri Jan 17, 2014 4:58 pm
Ok so the ezcar looks more sturdy than the hero hoist one, but then read this.....
http://forums.bimmerforums.com/forum/sh ... rLift-Pics
Scroll down towards the bottom and see where the ezcar collapsed under weight
Might be an isolated example but I don't want to be a second one :-)
Think I will stay with jack stands until I get a garage that can fit a hoist
NA8 94 Clubman
Postby Mr Morlock » Sat Jan 18, 2014 9:21 am
You would have to ask yourself would you lift a car like this and how safe do you think it is? Personally I would be very nervous about lifting it under the sills.
Pamex
Postby Pamex » Sat Jan 18, 2014 12:50 pm
To me they don't look like they give you THAT much more height than stands, but with a lot more cost.
I'm just using stands on mine and it looks to be about the same height as with this.
zossy1
Postby zossy1 » Sat Jan 18, 2014 6:24 pm
Mr Morlock wrote:You would have to ask yourself would you lift a car like this and how safe do you think it is? Personally I would be very nervous about lifting it under the sills.
Why? This is how all 2 post hoists work. Apart from the crossmembers, the sills are the strongest part of the car.
Users browsing this forum: No registered users and 22 guests
