Aftermarket B6 exhaust Manifold wont reach CAT!!! HELPP NA6
Hi,
I have a NA6 MX5.
I purchase a aftermarket exhaust manifold, its stamped B6 on the JASMA plate. The exhaust manifold is too short and won't reach the stock catalytic converter?
The seller said this was for NA6 mx5 N6 motor.
What can i do??
Thanks
I have a NA6 MX5.
What can i do??
Thanks
- Vehicle: ND - 2
Re: Aftermarket B6 exhaust Manifold wont reach CAT!!! HELPP
Hi.
I guess you know the jasma plate is not the manufacturer. It refers to the manufacturer being a member of the japanese aftermarket parts association.The fact it has b6 stamped on the plate is unusual. If your extractor has a flange on the end it should fit if no flange it has probably been cut to remove it. Have you lined the exhaust manifold which was on the car and the new manifold to see if one is shorter? The only thing to do is get an exhaust shop to lengthen the pipe.
ralt wrote:Hi.
Hey yep i know, but in little text it stats b6. I think on all Jasma plate it stats what mother the manifold is for.
Yep the manifold side lines up perfectly, but where the manifold flange meets the cat, its about 30cm too short ?? So confused.
How much would it cost to get my cat extended in the exhaust shop? Also do i need to bring in the whole car to do everything or do i just remove cat and get it extended?
Might as well sell it at this point too much trouble. >.>
Shouldn't cost more than 50 bucks at a exhaust shop ....... Probably less if you don't get ripped off ;-)
wade wrote:Shouldn't cost more than 50 bucks at a exhaust shop ....... Probably less if you don't get ripped off ;-)
$50 to get the cat extended and extractor installed?
What exhaust shop do you recommend in Sydney?
Thanks
- Vehicle: Non MX-5
wouldn't the extractors already be installed? otherwise how do you know they are too short?ZL wrote:wade wrote:Shouldn't cost more than 50 bucks at a exhaust shop ....... Probably less if you don't get ripped off ;-)
Thanks
project.r.racing wrote:wouldn't the extractors already be installed? otherwise how do you know they are too short?ZL wrote:wade wrote:Shouldn't cost more than 50 bucks at a exhaust shop ....... Probably less if you don't get ripped off ;-)
Thanks
I got the old extractor out and i realise the new one way to short to reach the cat >.> so i haven't installed either one in yet.
I won't be able to drive the car with the new one in. So i would have to install the old one back in for now.
- 91BRG
I have seen some JDM branded headers that are two piece like this one here
http://www.nengun.com/fujitsubo/roadster-na6ce-for-exhaust-manifold-402042
So you might be missing the end part which would explain why it's too short.
- Vehicle: Non MX-5
ZL wrote:project.r.racing wrote:wouldn't the extractors already be installed? otherwise how do you know they are too short?ZL wrote:wade wrote:Shouldn't cost more than 50 bucks at a exhaust shop ....... Probably less if you don't get ripped off ;-)
Thanks
makes sense.
i would just get a small section added to your current exhaust piping to bring the cat closer to you new headers.
install the headers yourself before you go to the exhaust shop to have it done. just will be a loud drive to the shop. much quieter on the way home.
^^^ this...... Any local exhaust shop will be able to weld a piece of pipe in, it's what they do all day .....
project.r.racing wrote:ZL wrote:project.r.racing wrote:wouldn't the extractors already be installed? otherwise how do you know they are too short?ZL wrote:wade wrote:Shouldn't cost more than 50 bucks at a exhaust shop ....... Probably less if you don't get ripped off ;-)
Thanks
makes sense.
Is it okay to drive without the header connected to the Cat?
Also how much would it cost to have a piece wielded to the Cat to fit the header?
Lastly whats a good exhaust shop Inner west sydney.
Thanks
- Vehicle: Non MX-5
1. I wouldn't do it all the time. The sounds is loud but amazing. Very race car.ZL wrote:project.r.racing wrote:ZL wrote:project.r.racing wrote:wouldn't the extractors already be installed? otherwise how do you know they are too short?ZL wrote:wade wrote:Shouldn't cost more than 50 bucks at a exhaust shop ....... Probably less if you don't get ripped off ;-)
Thanks
makes sense.
1. Is it okay to drive without the header connected to the Cat?
2. Also how much would it cost to have a piece wielded to the Cat to fit the header?
3. Lastly whats a good exhaust shop Inner west sydney.
Thanks
2. $50-$100, what eariler posters have estimated.
3. Google it.
