Na6 Headlight switch?
Rolley
Postby Rolley » Thu Jan 15, 2015 1:25 pm
I've dug through the big forum and checked out the couple of threads that are on here but I've not found anybody with this problem yet...
91' NA6 First time for the day/night that I turn the headlights on with the stalk switch they wont Pop-up.
-Parkers come on and if I hit the dash switch they pop and turn on.
-After about 5 mins I can hit the dash switch again and they stay up/on and will work normally from the stalk switch for the rest of the day/night.
-Also if I turn them on with just the stalk switch and just wait after a couple of mins driving they will pop.
It's like the relay needs to warm up or something.
I'm going to pull the stalk switch apart and clean contacts this weekend and check the relays (if I can find them).
My question is have any of you had this problem also? Is there anything else I should be checking?
myredmx5
Re: Na6 Headlight switch?
Postby myredmx5 » Thu Jan 15, 2015 1:33 pm
You probably need B481-67-7C0B
I have one.
SLO_NA
Postby SLO_NA » Wed Mar 02, 2016 2:31 pm
I had the exact same problem on my 91. I managed to get the headlamp retractor relay (B481-67-7C0B) from the wreckers and it solved the problem.
2005 MX-5 SE Turbo
2001 RX-7 Type RS
2002 RX-7 Spirit R Type B
2010 RX-8 S2 GT
2009 RX-8 S2 Luxury
2014 GT86
1996 MX-5 LE
1988 LN106 Hilux
Postby Magpie » Wed Mar 02, 2016 2:41 pm
I have no need for that relay in my MX5 anymore Rolley, I can bring it up to Roger's coffee meet on Saturday?
This may help
http://forum.miata.net/vb/showpost.php?p=4024005&postcount=10
zero00
Postby zero00 » Wed Mar 02, 2016 9:04 pm
Magpie wrote:I have no need for that relay in my MX5 anymore Rolley, I can bring it up to Roger's coffee meet on Saturday?
This may help
Good idea Magpie! Coffee Saturday morning :wink:
Roger D-SUNSHINE COAST
Postby Magpie » Fri Mar 04, 2016 8:45 am
Rolley will you be at coffee on Saturday? If so PM me the parts that you may need (and the approx. location) you need and I will get them from the shell in the shed.
