NitroDann's Long Awaited Garage Thread
deviant
Re: NitroDann's Long Awaited Garage Thread
Postby deviant » Fri Feb 20, 2015 10:34 am
I reckon it does make a difference at higher speeds, I did the same to my NB and that entire strip normally hangs down in the breeze...Any real advantage to be gained would come with managing airflow under the car though.
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
Postby lightyear » Fri Feb 20, 2015 12:10 pm
NitroDann wrote:Its limited to 280 ftLB at the wheels (calculated back to the engine). What did yours make? Even more right?
Should be okay. It really needs harder engine mounts though.
Can't remember the numbers exactly. But before he put on the extra external waste gate it was making about 450hp at 4000 or so rpm. He got it down to 380hp at 7000rpm. Also even less power/torque depending what gear it is in.
All pretty useless in a car that just sits in the garage.
Postby NitroDann » Fri Feb 20, 2015 4:02 pm
450@4000rpm would need around 40psi..?
lightyear
Infinity & Beyond
Postby lightyear » Fri Feb 20, 2015 4:15 pm
I found the txt.
374hp@6000rpm 18psi.
380lbft at full boost.
292hp at 5700rpm.
270lbft at min boost 7lb. Turbo rated for 370hp - maxed out compressor. Inj maxed out too. Rev limit at 7000.
He said 330hp is about the limit for the trans.
Postby NitroDann » Fri Feb 20, 2015 5:05 pm
That's a 1.9L also yeah?
lightyear
Infinity & Beyond
Postby lightyear » Fri Feb 20, 2015 10:06 pm
It's a 1.8 still as far as I know.
Postby NitroDann » Mon May 04, 2015 2:46 pm
An interesting photo I took that shows the behavior people talk about with stockish SE's.
You can see the low (yellow) line starts very low hp, and when the ecu goes open loop after emmissions testing rpm we get a bit of turbo HP for less than 1000rpm then hit the low redline.
I havnt seen dyno's for these cars just dríven them but I now have this one to show people. This car had the common ebay larger intercooler and a full 2.5" exhaust.
Cool huh
Postby NitroDann » Tue May 05, 2015 6:27 pm
PM's replied.
Yellow line SE performance mods:
2.5" magnaflow exhaust
Justjap FMIC
Purple line SE performance mods:
3" NitroDann exhaust
Justjap FMIC
NitroDann Intake
Haltech Elite1500 with NitroDann PnP harness, NitroDann EBC and NitroDann tune
Roadrunner
coyotes after you
Postby Roadrunner » Tue May 05, 2015 7:17 pm
That's my car (the yellow line, not the purple sadly :( )
Every stock SE driver can relate to that graph.
Amazing the difference an ECU will make to these cars power and drivability!
NitroDann certainly knows his stuff with these, was cool hanging out watching him do his thing :D
MeepMeep
bear2230
Postby bear2230 » Tue May 05, 2015 9:46 pm
NitroDann wrote:Haltech Elite1500 with NitroDann PnP harness, NitroDann EBC and NitroDann tune
How did you find the Elite1500 Dann? Are you becoming a fan or still keen on MegaSquirt.
Richard.
Postby Lokiel » Tue May 05, 2015 11:48 pm
NitroDann wrote:PM's replied.
Justjap FMIC
Justjap FMIC
NitroDann Intake
The "usual" bolt-on SE performance mods are CAI+larger exhaust+bumping the boost to 10psi + larger injectors (305/315/321cc); the intercooler isn't a performance mod.
With these mods, users can expect at least 145rwkw (194rwhp) but the car will run like crap since the factory ECU cannot cope with this increase (the stock SE supposedly puts out ~110rwkw/147rwhp).
The larger exhausts adds ~10rwkw whereas the CAI + boost increase adds ~25rwkw which is closer to the purple line.
The graph nicely illustrates the benefit of an aftermarket ECU.
- are you going to put in any more effort between 3100..3650rpm to flatten it out more?
Postby NitroDann » Sat May 16, 2015 7:14 pm
Straight off my facebook page, for more details LIKE it and read some more :)
Postby Lokiel » Sun May 17, 2015 9:27 am
NB with stock internals @ 257.7rwhp - this should be pumping out on your stereo at the track:
Postby NitroDann » Sun May 17, 2015 10:15 am
Torque is also represented and as you can see its going to be just fine. :)
Postby NitroDann » Wed Jan 20, 2016 9:49 am
Thread-surrection!
Thought Id throw up some recent pics and let everyone ask questions and discuss the variables. Lots of people are interested in what parts go into producing these results, and the process and costs involved.
So here is the engine bay:
And the Dyno Sheet:
And the Compliance Certificate (Engineering cert.):
What it has that it NEEDS for the performance.
Edexy HD Organic
GT2560r
Manifold/downpipe exhaust (even a log and 2.5" could achieve this with more boost)
Standalone ECU (MS2)
ECU based electronic boost control
FMIC kit
Big injectors (overkill ID1000 in this case)
Oil feed and return
Air filter setup (tube and pod)
Options for reliability:
Reroute (water flow and temperature management)
Radiator (as above)
Braided oil AND water lines (Keeps the turbo bearings cool after shutdown)
Inconel studs/Stage8 locking hardware (keeps the turbo on the manifold and the downpipe on the turbo, no exhaust leaks at the track)
Exhaust flex pipe and brace (keeps the swinging exhaust forces which are HUGE off the turbo hardware)
Resbond locking compound (keeps the studs in the turbo)
Mazdaspeed engine mount on the turbo side (turbo side is the one that breaks)
Options for legal certification:
Euro4 cat (to help pass IM240)
Airbox intake (needed for street use)
Recirculated blow off valve (keeps the noise down)
Big muffler (to pass sound test, its still straight through however and sounds awesome- I recommend this exhaust option whether engineering or not)
Overkill options because why not:
Frame rails (protect the oem rails)
Walbro intank pump (the OEM one is great but this one was worn out so we stepped it up)
Toyota COPS (gives great starts and lets us completely forget about possible misfires even if the plugs are a little dirty, its a hot day, and we are flogging the tits off of it)
Then there are a series of tests that the car has to pass and its back on the road legal.
Feel free to ask tech questions about any of it.
Users browsing this forum: No registered users and 27 guests
