What fuel should I run?
Jessegroves
Postby Jessegroves » Sat Oct 03, 2015 11:24 am
I have a 1990 NA, I've only filled up twice using 95 and 91.
What do you guys run? What do you recommend? The engine is stock, zero performance upgrades installed.
Trackphotos
Re: What fuel should I run?
Postby Trackphotos » Sat Oct 03, 2015 12:02 pm
Octane is only a measurement of how much heat/pressure it takes before the fuel will flash ignite/knock. The engine is designed for 91, so putting 95 or 98 in it will not improve performance purely by being a higher octane. It may however offer other benefits by way of different ingredients used in the more expensive fuels, detergents and other things. Generally though, there's nothing to gain on a standard engine designed for lower octane fuel, other than a slightly higher fuel bill. It wouldn't be a bad idea to run 95 if you were to take it on a track, just in case your cooling system turns out to not quite be up to the job, but I imagine if that were the case you might have bigger concerns.
StanTheMan
Postby StanTheMan » Sat Oct 03, 2015 10:02 pm
I got better fuel economy with 16 deg of advance. That's with 98. Do your maths.that was in the days where it was maybe 5 or 6 c more expensive. Now days it's far more.
I find a good compromise with 95. Engine seems to like it. Runs smooth. But it also depends on how often you drive it. Fuel seems to go off after a few months in the tank.
Currently I take about 4 weeks to go through a tank.
Jessegroves
Postby Jessegroves » Sun Oct 04, 2015 1:14 am
Mines a daily car, I drive it most days, not long trips though, doesn't get dríven too hard either.. I think I'll stick with 95 when I can or else 91. I don't think I'll bother with 98
Apu
Postby Apu » Sun Oct 04, 2015 7:36 am
95 is more than good enough. I run 98 only because my car has been turbo'd and was tuned on that...I'd go to E85 if I could find a convenient supply.
Nevyn72
Postby Nevyn72 » Sun Oct 04, 2015 8:48 am
Also remember that Mazda states that any pre-2005 vehicle is not suitable for ethanol.
So if you do want to use 91, avoid E10 blends. :wink:
I use 95 in my '02 Astina, the car runs a lot better than with 91 and is more efficient.
I tried stepping up to 98 but there was no further improvement......
I only use 98 in my MX5, but it's a turbo so...... :mrgreen:
smy0003
Postby smy0003 » Sun Oct 04, 2015 10:50 am
Slightly of topic, but I have trouble finding 95. 98 is easy to find at the big ones and also e10 at United, but I rarely see a 95 pump.
Am I going blind or are the big chains ditching 95 for 98 because of the extra profit?
*puts on tin foil hat*
Sent from my GT-I9505 using Tapatalk
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Red Dragon
Postby Red Dragon » Sun Oct 04, 2015 9:42 pm
BP has a yellow handle for 95
Caltex has a blue handle for 95
I never use shell so i don't know about them
Postby hks_kansei » Mon Oct 05, 2015 11:43 am
Red Dragon wrote:BP has a yellow handle for 95
Red handle is 98 for shell.
Yellow I think 95.
Blue regular.
As for the OP re: fuel, 91 is fine, 95 will give better resistance to knock (not really a risk in an NA)
If you've advanced timing, run 95.
Most of the 98 octane fuels do have additives such as detergents etc, which can help keep sh*t from building up.
I tend to put a tank of 98 through maybe once every few months.
wasabi
Postby wasabi » Tue Oct 06, 2015 11:19 am
I'm running 98 in my SE, but it's been tuned for it so don't have much of a choice :P
In previous cars I've had which could run anything from 91 & up, I still used 98 - Albeit, cost difference was a lot less then it is nowadays! Generally speaking the additional range I got with 98 justified the additional cost. Didn't do anything for performance as others have stated, but it felt like that cars ran smoother - Could just have been me though :P
Given the premium in price, the only reason I'd suggest running 98 in a stock car that doesn't need it is because of the mild injector cleaners & other bits & pieces that are found in them. If you're going through a tank of fuel every week or so, maybe run 98 every 2nd or third tank.
2004 SE - WASABI Jr - Enhanced by Deckspeed
SMSP Brabham - 2:17.7
SMSP GP - 1:54.4
SMSP Amaroo - 1:04.9
Wakefield Park - 1:11.8
smy0003
Postby smy0003 » Tue Oct 06, 2015 12:30 pm
Here's a question, I ride my bike a lot and the car sometimes has the same tank of fuel for a month or more, I use 98 because a) the amount of kilometers I travel makes the extra cost less noticeable and b) I assume 98 goes stale less quickly.
Is this actually the case?
rascal
Postby rascal » Tue Oct 06, 2015 12:53 pm
wasabi wrote:Generally speaking the additional range I got with 98 justified the additional cost.
In my previous Mazda (KL V6 - stock as a rock), I got almost exactly 10% better economy using 98 over 91 (repeatable over 4000km test) .
Therefore on my usage if 98 is less than 10% more expensive than 91, then its actually cheaper to run the better fuel.
Throw in the added benefits of the better fuel and its a no brainer to use 98 all the time..
I haven't used anything other than 98 for years now..
Steerpike
Postby Steerpike » Wed Oct 07, 2015 1:10 am
smy0003 wrote:Here's a question, I ride my bike a lot and the car sometimes has the same tank of fuel for a month or more, I use 98 because a) the amount of kilometers I travel makes the extra cost less noticeable and b) I assume 98 goes stale less quickly.
Nope. 98 does not go stale less quickly. 91, 95 and 98 are all made of the same components, just in differing proportions. In any case, one tank of any fuel will not go "stale" in a month or so. No need to worry, even if the fuel is a few months old. My mower probably still has fuel from last summer in it. Still runs fine.
Postby Magpie » Wed Oct 07, 2015 4:23 pm
Like others my tune only allows the use of 98 or E85. However I struggle to put 98 in it these days and if I have to only enough to get me to a servo that sells E85 (United) of Flex Fuel (Caltex).
