sailaholic wrote:I have the HEL branded lines.
Hel Australia list the same part no. for all MX5's from 1993 to 2005, but mx5parts UK list a separate part no. for the larger NB2 brakes. Different lengths ?
Where did you buy yours sailaholic ?
The Green Goblin wrote:I have since found that the right rear line is leaking at a mounting point...
As for the leak in the rear...
93_Clubman wrote:The Green Goblin wrote:I have since found that the right rear line is leaking at a mounting point...
I've had rear brakes go on the road due to brake fluid leak after an hour or so of driving - was driving the vehicle home after purchase - indicated to turn right & applied brakes only to find pedal went all the way to the floor - given it's been some weeks, hope you're in a position to not have to be driving the vehicle.
yertimer wrote:Hi,
Slightly off the point (sorry) - but can someone tell me how much difference braided brake lines make on a track like Wakefield park or Amaroo / SMSP south? Do you get better brake pedal feel? better safety? better times? all the above?
Assuming you run them with OEM discs and callipers and street / track pads etc are they worth the investment?
Users browsing this forum: Bing [Bot] and 6 guests
