So I took a piece of cardboard and drew out a simple template.
Then I got the Jigsaw out and chopped up the OMGPHAM cops mount according to the template and fit the bits onto the cam cover, some additional nuts, bolts and brackets were needed to fasten them to the stock threaded holes but thats easy.
I spent the good part of an afternoon doing the wiring and making them nice and need on the cam cover:
A quick bit of insight at this point, the fab9 COPS kit is actually very good value as I spent about the same amount of money with my DIY solution. So if you want to spare yourself the trauma and headache of trying a engineer your own solution using a misfit collection of random parts - get the premade it. The special automotive connectors alone for the the cops plugs and the ingition module cost me about 100 bucks from Mouser electroncs, and the shipping from those guys weren't cheap at all, from memory it cost about 50 bucks to ship a handful of plastic plugs.
I was so stocked when I turned the key and the engine started instantly! The solution that I designed works!
Better yet the cranking when starting the engine is much quicker, engine revs more responsively, better idle and it purrs!
Definately recommend this mod to anyone who is keen, very rewarding.
