Hey guys
Just wondering where can I get the Ohlins DFV coilovers from and how much would it set me back?
Ohlins DFV coilovers for NA8
- bear2230
Re: Ohlins DFV coilovers for NA8
Steve Cramer Products
Product Areas
ATV, Automotive, Motorcycle
Address
PO BOX 1064
BRAESIDE, Victoria 3195
Phone
+61 39587 1466
Fax
+61 39587 2018
Email
ohlinsaustralia@stevecramerproducts.com.au
A little over 2 grand I think. Check with Regie he has them.
Richard.
Product Areas
Address
PO BOX 1064
Phone
+61 39587 1466
Fax
+61 39587 2018
Richard.
- pcmx5
- Vehicle: ND - 2
If you are interested I have a set of Tein Street Flex Z's brand new in box for $1050 in Geelong.I think the Ohlins are around $2500 and probably worth it but if you would consider the Teins it is a good deal.Good luck with whatever you do.
Peter.
Peter.
- pepejesus
If you're the market for the Ohlins I would strongly suggest you also consider MCA Reds http://mcasuspension.com/
You get a very high quality custom spec'd set of coils tailored to your application for about the same price as the Ohlins. You should also consider the cost of replacement springs in the Ohlins if your goal is to track the car as the stock rates in the Ohlins are softer than optimal if you're running sticky tyres.
I've not got any personal experience with either brand but have heard good things about both.
Barbagallo long: 70.488
Barbagallo short: 58.999
- bear2230
I have MCA reds on the white car and they are phenomenal.
Richard.
Richard.
