Ohlins DFV coilovers for NA8
BRG.NA8
Postby BRG.NA8 » Tue Apr 12, 2016 9:26 pm
Hey guys
Just wondering where can I get the Ohlins DFV coilovers from and how much would it set me back?
bear2230
Re: Ohlins DFV coilovers for NA8
Postby bear2230 » Tue Apr 12, 2016 10:25 pm
Steve Cramer Products
Product Areas
ATV, Automotive, Motorcycle
Address
PO BOX 1064
BRAESIDE, Victoria 3195
Phone
+61 39587 1466
Fax
+61 39587 2018
Email
ohlinsaustralia@stevecramerproducts.com.au
A little over 2 grand I think. Check with Regie he has them.
Richard.
pcmx5
Postby pcmx5 » Tue Apr 12, 2016 10:42 pm
If you are interested I have a set of Tein Street Flex Z's brand new in box for $1050 in Geelong.I think the Ohlins are around $2500 and probably worth it but if you would consider the Teins it is a good deal.Good luck with whatever you do.
Peter.
pepejesus
Postby pepejesus » Wed Apr 13, 2016 5:43 pm
If you're the market for the Ohlins I would strongly suggest you also consider MCA Reds http://mcasuspension.com/
You get a very high quality custom spec'd set of coils tailored to your application for about the same price as the Ohlins. You should also consider the cost of replacement springs in the Ohlins if your goal is to track the car as the stock rates in the Ohlins are softer than optimal if you're running sticky tyres.
I've not got any personal experience with either brand but have heard good things about both.
Barbagallo long: 70.488
Barbagallo short: 58.999
bear2230
Postby bear2230 » Wed Apr 13, 2016 6:35 pm
I have MCA reds on the white car and they are phenomenal.
Richard.
