97 MXV's NA8 Gender Transformation
97 MXV
Re: 97 MXV's NA8 Gender Transformation
Postby 97 MXV » Sat Apr 08, 2017 10:10 am
97 MXV wrote:Image
The Baseline is this....One Diameter (1D) Thread Engagement....At 1st glance it is enough given that the a typical nut is only 10 mm....BUT !
It is true that 1D thread engagement is considered enough for threaded joints while things are good and tight. However if the locking nut gets loose, 1D thread engagement will wear out and catastrophically fail much quicker than 1.5D thread engagement.
The potential is real world failure modes of this steering joint with lower than OEM thread engagement. The presence of fine threads suggests that it won't get very sloppy before being able to finally pull out.
Now imagine the steering rack actually not centred properly when the thread is adjusted at "The Tyre Shop". 1D can easily be less than 1D on one side and more than 1D on the other, because it is impossible to see thread engagement directly. It must be inferred and inference can easily lead to error.
Furthermore the locking nut is tensioned against the tie rod end by opposing open ended spanners, the most unreliable spanners and tensioning method imaginable.
Beware The Tyre Shop Factor and the mental hazards everywhere lying in wait. :shock:...Truth is, an extended ball joint requires a high quality, robust Maintenance Strategy.
We all know that shaking hands with the boss at The Tyre Shop is not the same as shaking hands with Murphy, that eager to please Intern from "Kazakhstan" assigned to the job at the last minute because the normal mechanic briefed by the boss had to suddenly manage a crisis at home.
Imagine Murphy forgetting to count enough threads for a dear life to hold on to. And imagine a loved one picking up the car from The Tyre Shop, not remembering to double check.
And imagine checking one side and not the other or dismissing a small difference in exposed thread as insignificant.
Imagine the doomsday scenarios never ending when there are not enough threads for Murphy to play with.
Or to put it another way, what hope is there for soft barriers of defense being effective on that fateful day in the future when steering performance is demanded as a matter of life and death if not enough hard barriers are left after Murphy got the holes lined up in Swiss Cheese with a screw loose.
A high quality and robust Maintenance Strategy starts with a proper System Description including proper specifications of this new extended lower control arm system. Proper specifications have not been found in supplier's sales specifications to date.
One place to start proper specifications is to identify the presence of a "new system in place" to Murphy by painting the extended ball joint a distinctive differentiating distinguishing colour.
The second place is to start testing the significance arising from a Murphy Event. Now a decent 12mm bolt will handle a tension of say 9 tonne and tie rod loads are likely less than 1 tonne.
Such significance testing suggests the issue is not be so much the strength loss with fewer threads, but perhaps the friction loss with fewer worn threads.
Even a few threads engagement is stronger than the compression strength of the tie rod. The thing to fail first is the tie rod buckling and that won't happen cornering on a flat surface.
Reduction in thread friction from wear in a loose thread means there is less torsional restraint on the tie rod.
Whether it is possible for an unscrewing torque to be generated in a tie rod responding to suspension movement, gyroscopic and wheel frequency vibration is another matter entirely.
In any case I see nothing to lose having a Maintenance Strategy which focuses on means to ensure ample thread friction and robust tightening of the lock nut.
A tight nut is actually a good thing as the deflection in the thread from tightening can prestress the threads so their contact surfaces cannot fret in normal use.
Therefore significance testing is starting to point me in the direction of optimum nut tightening strategies and then only last resort use of thread locking compounds.
A Maintenance Strategy might be to toughen the joint against cyclic "shock" loading by increasing the stud length of the exposed threaded part of tie rod using a steel spacer between the tie rod end and a heavily pre-tensioned nut in place of a jam/lock nut.
Adding a 20 mm diameter and 12 mm thick, stiff steel spacer and significant pretension is enough to create a significantly tougher joint that is less likely to suffer from fretting in the threads from normal cyclic loading even though stress in the 1st few threads would ultimately be higher.
The bolt volume under the stiff spacer is able to act more resiliently against normal cyclic loads which otherwise tend to stretch and fret the first few threads in the stiff tie rod end.
In effect more threads are mobilised by higher pretension but stress change in the threads is lower because of the different stiffness of the spacer and the tie rod under the spacer.
Whilst not yet verified, a thickness of only 12 mm should make a worthwhile difference with the presence of a spacer shaped as a pre-tension indicator/pointer free to rotate down under gravity if there is total loss of pretension. :idea:
On that point, I could imagine Murphy focusing on the task a little more if there were official 43mm long, 3D printed plastic thread engagement indicators fitted to the tie rods.
Maybe I will talk to mrpham, good pal buddy to see if his latest technology can help demonstrate these extended lower ball joints have potential for commercial acceptability after all.
All I need to do now is laser cut a pair of 12 mm thick steel spacer/pointers, find a pair of hardened steel washers; then clean up and oil the threads before installing and pre-tensioning with new nuts, pop on the plastic thread engagement indicators and its almost done !
97 MXV
Postby 97 MXV » Sun Apr 09, 2017 8:43 am
An alert posted on a Group Buy has a response form madjak indicating longer tie rod ends have actually been made because he actually bought a pair !
Now I am on a Quest for the Holy Grail.......those longer tie rod ends......where are they ?....can anyone see them ?
Postby 93_Clubman » Sun Apr 09, 2017 11:39 am
97 MXV wrote:...those longer tie rod ends......where are they ?....can anyone see them ?
Not sure if longer, but these are different angled:
viewtopic.php?f=44&t=70556&p=909895#p909895
97 MXV
Postby 97 MXV » Sun Apr 09, 2017 7:39 pm
If I have got this right, in this photo linked by 93_Clubman, the ball joints used in NAs fitted with Bilsteins look different in length of shank but maybe not overall.
It would be good to get all relevant dimensions of each to know once and for all.
The joint on the right seems its shank might just be long enough for cutting short, screwing home tight and permanently thread locking in a "stealthy" high tensile extension. :D
97 MXV
Postby 97 MXV » Mon Apr 10, 2017 8:17 am
They say pets and their owners sometimes look alike. :D
Can the rear end of this horse reflect the "shiny ar$e engineer" behind the wheel ? Lets start with those rare Japanese chrome rear lens surrounds.
They are an after market accessory now "out of print" in Japan, and subject to future research in my Road&Ster magazine collection.
The remnant black garnish is part of alter ego Darth, but to complete the shine, the Plan is to trial a chrome vinyl wrap a spare rear garnish, not the whole car !
A lot will depend if the extra shine will ever able to be shown to rivals on the track.
Pics taken before doing latest negative camber and ride height changes.
The soft top is a rare NB fabric glass top one which came off an import JDM special edition if I recall correctly.
Fabric is useful because it seems to store well when down which is hopefully most of the time.
The polished stainless fuel lid is a Japanese Runabout Type 2. (The Runabout Type 1 has no exposed screws)
Chrome plastic strip from China is resplendid on the bumper and a nice touch to the rubber trim normally earmarked for a tonneau cover rendered useless by the roll bar.
The spoiler is a Mazda factory option collected with a boot lid, then to have its horns docked off and the gaping wound left, bogged up.
However it will probably now come off as I was horrified and so dismayed to see the wind tunnel test image in an earlier post showing it might be functionally challenged.
Therefore I would rather see it go to make way for the tyre rack shown in an earlier post as that actually will be useful.
Any takers for this fabulous looking spoiler ? I will advertise in due course on this forum. It is just taped on at the moment.
The rear mudflaps are the magnificent later model NA8 long one piece mudflaps that came standard and provide a strong fashion statement yet to be written.
Lurking in the back yard is a spare bumper keen to mate with a fake diffuser. However my motivation for latest fashion is ultimately tempered by its usefulness.
Therefore a nice standard bumper look is safe for a fair while longer.
The large chrome tip emerging so nicely in this pic is part of a lovely quiet stainless Autoexe rear muffler and tip. The rest of the exhaust is standard NB8B.
Fitting the NB8B system required changes to the hangers to suit as NA and NB exhausts hang differently from NA exhausts.
I did not document the hanging, except to say it was not an execution of pure design but was rather a neat looking improvisation.
Not sure how much information is needed but I can go down under and take revealing pics to show that it's very well hung.
Dean.H
Postby Dean.H » Wed Apr 12, 2017 9:27 am
97 MXV wrote:Given what is presented here I warn against an advertised specification beyond 3 degrees negative....some could argue less...few would argue more.
Therefore to support such a specification I believe extended tie rod ends should also be offered by Bauer with the extended lower ball joints as matching pairs.
Have you taken this up with Bauer?
I have had some contact with them and whilst I wasn't overly happy as my ball joints had developed vertical play, they were fairly approachable and replied to emails etc.
97 MXV
Postby 97 MXV » Wed Apr 12, 2017 11:11 am
You hit on an extremely critical matter to feed back issues like this to the manufacturer because it is far better they do something about how we use their product than we, the users do.
We are told Safe Design is always "Safer at the Source" than us trying to fix things.
I imagine Bauer will be very impressed that there is so much serious interest in our use of their product from all the way Downunder.
I feel I have enough feedback and info now to make a serious case to them. Who knows they might have something in the wings already. :D
I temper that enthusiasm knowing small American manufacturers operating under the radar of taut lawyers or a Nanny State are mostly motivated if they see a buck in helping.
That is why the more customer voices in sync with an agreed approach the better, like from Group Buys.
Lone voices in the wilderness often have little influence in America unless money is at stake or one makes a bit of noise.
Postby Lokiel » Wed Apr 12, 2017 5:03 pm
97 MXV wrote::
If you're looking for functionality and style, why not do a modest bumper cut to help eliminate "the parachute effect"?
97 MXV
Postby 97 MXV » Wed Apr 12, 2017 6:19 pm
Lokiel wrote:If you're looking for functionality and style, why not do a modest bumper cut to help eliminate "the parachute effect"?
I must admit that sounds much more tasteful and achievable and useful for showing off Autoexe rear muffler.
Less room for stickers and will reduce size of parachute which when the car is lowered, doubles as a scoop for small native road kill.
97 MXV
Postby 97 MXV » Thu Apr 13, 2017 4:04 am
Request for their involvement sent yesterday via Bauer website contact form
97 MXV
Postby 97 MXV » Thu Apr 13, 2017 4:58 am
Another thing I like with this rear end is its super shiny Haute Couture taillights almost as good as Sparkleys.
They look so shiny, Sparkley would love some made for her fashion wardrobe to wear on more formal occasions.
I do worry now that she is a girl that she might become as demanding as Lokiel's Gina seems to be.
97 MXV
Postby 97 MXV » Sat Apr 15, 2017 9:55 pm
Yesterday was a Good Friday for a Sparkley test run, this time with an instructor on board while my wife is busy bringing home the bacon in China.
It was a 1st outing in Sparkley with Cruella Deville, happily by my side while I was in total command demonstrating Sparkley's cornering prowess on West Mount Cotton Road. :twisted: .
She had a ball as a navigator trying to tell me where to go while the engine roared and the wheel whipped back and forth confused by her directions as the tyres clawed back at high speed from the edge of the abyss that I imagined was the mountain's western escarpment to nonsensify the story.
Then we stopped for a quiet coffee at a nursery at the end of the run and mused how well Sparkley handled the conditions, then drove back again in the opposite direction to savor the experience and assess possible areas for improvement.
I had Sparkey's Ohlins PCV Coilovers like these prepared earlier by zoomzoom, set at three quarters soft, and she agreed they worked a treat.
She was quick to suggest plush riding radials with longitudinal groove tread on supple radial cords rather than the R888 lateral grooves on rigid bias ply cords, better to suppress or eliminate the dominate lug pass frequencies exciting the experience.
It was a good lesson to find out from her 1st hand that the Toyo R888's as much as I love them, are just not loved by hot chicks with experience.
In my case, experience in nailing an innocent man to the cross, but don't cry as I should recover by Easter Sunday.
Sunday will ultimately mark the resurrection of the tyre rack from the grave, from the pile of bits which may come in handy one day.
With comfort a priority over life, she gave the semi slicks the sack, but they will get a crack on this rack at the track.
So now I am on the hunt for some nice quiet luxury riding radials to fit spare 15 x 7 Enkei LM8s rims. Soft grippy compound tyre preferred.
Any recommendations for a smooth quiet riding tyre and thoughts on size ?
195/50/15 is my preference at the moment.
mx5002
Postby mx5002 » Sat Apr 15, 2017 10:26 pm
Can recommend re003's
Or Hankooks rs3's, they have a soft sidewall for a semi slick. Not sure about the quiet but though
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64 :D
97 MXV
Postby 97 MXV » Mon Apr 17, 2017 10:02 am
This is how Sparkley looks with 3 degrees negative at the front. A fairly moderate stance at the front I think.
This is how Sparkley looks with 3.5 degrees negative at the rear. A fairly moderate stance at the rear I think.
This is how Sparkley looks raised up from before. Still looks sporty I think raised 30 to 40 mm higher than alter ego, Darth..
97 MXV wrote:Currently Sparkley is sitting at 320 mm front and 330 mm rear using the accepted wheel centre to guard lip dimension method...setup at home
The West Mount Cotton Road test had its share of dips that simultaneously tested bump stop reactions under increased "g" at high speed.
The Ohlins adjusted to the new ride height seem to handle those conditions pretty well.
Postby Lokiel » Mon Apr 17, 2017 11:04 am
97 MXV wrote::
This is the perfect rear bumper cut IMO - and how the car should have come from the factory!
Maybe not as effective as a more extreme cut but aesthetically looks great.
One day I plan to buy another bumper and do this on my MSM/SE (the MSM/SE has an add-on rear bumper bit with "rear diffuser fakie" on the bottom edge):
- I don't like destroying rare pieces and prefer to buy a second bumper to modify.
- it's ironic how the MSM/SE's rear bumper is imitating a rear diffuser, who's purpose is to increase air flow, but it actually impedes smooth air flow.
97 MXV wrote::
You're lucky she is so demanding, she "made me" buy the flat-top/square-top manifold from you many moons ago without haggling over the price.
