Patchy's Fawlty Towers risk management. Enter at own risk
- StanTheMan
Re: Patchy's Fawlty Towers risk management. Enter at own risk
well as usual Ive ignored patchy for some time and it has now become a rush to get the engine in & re-registered. I'm moving house & the new house has no off street parking , or garage.
This weekends job is to re do the cams gaps.and get the head screwed down solid
after getting the valves redone thy were all .2mm closer or deeper into the head so the gaps of the cam & lifter is too close.
new heavier springs have also been installed to cope with the big came at a later stage.
The decision has been made to re-install the standard cams for now so Patchy has an easier time to pass the blue slip cause shes been out of rego for around 6 month now.
the MS2 will get removed & the standard ECU will get reinstalled. same with the AFM
the standard exsaust header will also be used
on the verge of purchasing a new clutch.
its now all about getting the engine in & getting some rust cut out so she can pass the blue slip.
I need to also get more familiar with what is involved with the blue slip.
- StanTheMan
This is getting out of controll.
I coulnt afford the RB bling. Next best thing. Polished guard for NB8B headers with the usual Nitro Dann mods .....
Starting to feel like im polishing a turd.
Sent from my SM-G935F using Tapatalk
- StanTheMan
OMGlook what ive just found. Old crome pipe from the B6 motor. I doubt i can find the crome bolts. I tgink this is staying for now....
- StanTheMan
Yes i know the front of the cam cover needs lots of work still....
- ManiacLachy
- Engaged
- Daffy
ManiacLachy wrote:So shiny!
AND CHROME
- StanTheMan
Earlier today.
Its now time to clean & swap over parts.
Waiting for a clutch & a few other pieces.
Your new theme song:
- that chick was HOT!
- StanTheMan
OMG LOOK WHAT IVE FOUND!!!!!!
Small things amuse small minds.
- StanTheMan
I guess that makes it almost complete set id NA6 cam cover bolts on the BP-4W
Im totally soo farking pumped.
Homage to the B6 turd. LOL
- StanTheMan
I recon i might buy a whole engine just to get the one missing bolt....
Mmmmm....errrr....unlikely.
- StanTheMan
- StanTheMan
Ejaculation
- StanTheMan
Pics should be in reverse order. Clutch & gearbox were assembeled this morning. Had some drama getting the engine mounts in. But its all there.
Might have her running tomorrow.
Probably will fit the standarx airbox fir blueslip
