Perthpom50 wrote:I have to say that the installation was a bit of a pain.
For a kick of the dash removal tools that I ordered from Amazon got lost. Then a really nice man from the AutoBarn store in O'Connor lent me his removal tools as he had none for sale.
Getting the old radio out was no where near as easy as it is made to look on you tube so the surrounds have a few small extra scratches.
I had removed the radio from my old NA and that was a piece of cake, as well the cage holding the radio in would have been easy to use with the Joying.
I have ended up the original springs attached to the Joying to make sure that it never falls out completely. I then bought some half rubber moulding from Clark rubber which is what holds the head unit firm. I'll see if I can take some pictures in the next few days although I have had a gutfull of getting it in and out, I'll see what I can do.
The unit its self is this one which I bought from Jordy on the MX5cartalk facebook page
https://m.ebay.com.au/itm/7-Android-Tab ... mwBanner=1
Lokiel wrote:Perthpom50 wrote:I have to say that the installation was a bit of a pain.
So is the unit just wedged in place by the rubber?
I tried fitting an EONON unit and gave up because I couldn't mount it securely:
- I MAY have been able to get it in securely using custom spring-loaded clips that clicked into custom slots but there was no way I'd be able to get it out again - the front fascia extending around the unit when it was mounted gave no access to the top, bottom or sides of the unit.
I ended up buying a Joying unit with a detachable face - the main unit was only a single-DIN size so I made a custom bracket for it and clipped the double-din detachable face into it - took AGES to get it all lined up nicely:
Perthpom50 wrote:Having gone through all the trouble of changing it I am now looking at selling the SP in favour of an SE. I will be more comfortable with something that is not so collectabble and that i won't mind changing from stock. Watch this space.
KevGoat wrote:Perthpom50 wrote:Having gone through all the trouble of changing it I am now looking at selling the SP in favour of an SE. I will be more comfortable with something that is not so collectabble and that i won't mind changing from stock. Watch this space.
I drove an SP before I bought my SE and was very tempted, but had the same thoughts that I'd be too paranoid about modding it over an SE. Even on the SE I tend to only change what I can easily reverse.
Lokiel wrote:Instead of an SE, you should consider a N/A NB8C and turbocharge it properly.
NA6089 wrote:New Mahogany handbrake grip in progress
Users browsing this forum: Bing [Bot] and 8 guests
