Barton's NA6
bartmanftw
Re: Barton's NA6
Postby bartmanftw » Tue Jan 15, 2019 8:17 pm
Intake fitted but not finished. Need to weld on some hose barbs for bov return and crank case ventilation as well as change the last silicone joiner to a 45 degree to get the air filter away from the exhaust.
Definitely also needs a heat shield over the turbo and manifold.
Also if you're wondering, the black thing in the intake pipe is a GM MAF.
Re: Barton's NA6
Postby 93_Clubman » Wed Jan 16, 2019 8:39 am
Great work!
bartmanftw
Re: Barton's NA6
Postby bartmanftw » Thu Feb 07, 2019 10:31 am
Car is up and running now although not quite finished. Moved the intake over a bit with a 45 degree joiner however I need to figure out how to get air from outside the engine bay to improve intake temperaturs further. Obvious choice is to cut a hole in the firewall and get air from the cowl area but not sure how I feed about cutting into the car for that.
Intake temps aren't too bad anyway but could possibly be improved with a cold air intake.
Did a test on the freeway at 100km/h when ambient temp was ~28degC. Held WOT while holding the handbrake to prevent vehicle speed from increasing for about 11 seconds. Intake temps increased ~10 degrees over that time from 33 to 44. Boost pressure was 140kPa so going higher should make the temp increase worse.
3gress
Re: Barton's NA6
Postby 3gress » Mon Feb 11, 2019 7:31 pm
Interesting build mate.
Keen to see how the water to air charge cooler setup performs. I have always figured I'd use a pwr air/water heat exchanger if I ever get around to installing the rotrex charger kit.
bartmanftw
Re: Barton's NA6
Postby bartmanftw » Fri Jun 21, 2019 7:40 pm
Couple of updates.
Swapped my OEM hardtop out for a Lightyear carbon fibre one.
Nice weight saving but did require a bit of work adding seals to the side windows and I might need to re-seal the rear window since it might leak in heavy rain. Not a huge deal though..
Also had some some help making a heat shield for the turbo and manifold. Very happy with the end result. Definitely helps keep the components over on that side of the engine bay a bit cooler which is good since my relay controller for the water pump is located there. I had some concern with how well it would continue to work when getting very hot.
I have also added a radium fuel pressure regulator housing with a Bosch 60psi regulator and a NB8B fuel rail to create a returnless system. Well its sort of returnless since the fuel still comes up to the regulator and then back to the tank however it no longer passes through the fuel rail. Made for simpler hose routing and possibly will reduce fuel temps. The regulator is still manifold vacuum referenced as well. Can see it located just behind the intake manifold. Now I have to go back and re-calibrate my fuel tables...not a huge deal since the plan is to get the GM MAF working and use that for steady state fuel calculations anyway.
bartmanftw
Re: Barton's NA6
Postby bartmanftw » Thu Nov 21, 2019 6:51 pm
I haven't really had much time for this car over the last year due to work but a few things have happened.
Forgot to show the relays I added for the secondary radiator fan and intercooler pump
Harness plugs into the original blanked AC relay connector under the drivers headlight.
Swapped my 6ULs for some Advanti Storms 15x9.
I also recently took out the MS3x ECU to add a MAF frequency input but I can't stand how messy it all is after all the changes I've made over the years so I've decided to design an adapter board to use a MS3pro gen1 ECU I have been holding onto.
I've made something similar for a mates RX7 FD however I'll be adding a few more things onto the adapter board like a secondary 5V reference voltage supply so that if there is a short the ECU will still keep running.
bartmanftw
Re: Barton's NA6
Postby bartmanftw » Tue Dec 24, 2019 11:44 am
MS3pro PCB adapter board is assembled! Now just need to make the patch harness to go between this board and the ms3pro. Just waiting on some new wire to do that. The board has a USB and serial connector for communication to the ECU, two superseal connectors (commonly used on aftermarket ECUs like Motec and Haltechs), the MX-5 ECU connector to match the OEM harness, some pull-up resistors for things like temperature sensors etc, and a relay to control power to the wideband controller.
I've also got my MAF working and roughed in a airflow curve for it. Very easy to calibrate however it doesn't appear to be accurately measuring low airflow around idle, probably since it's in a 3" pipe and there's a bend right before the MAF. In the future I will replace the pipe with one that has airflow straighteners which should fix it but for now I can canfigure the ECU to blend the old speed-density tune at low airflow.
I also installed a set of superpro poly bushes in the a-arms so needed to get a wheel alignment.
Bonus picture of my cat in a box.
lucmor444
Re: Barton's NA6
Postby lucmor444 » Tue Dec 24, 2019 1:07 pm
Who did your alignment Alex?
bartmanftw
Re: Barton's NA6
Postby bartmanftw » Tue Dec 24, 2019 1:23 pm
lucmor444 wrote:Who did your alignment Alex?
MyCar which used to be Kmart tyre and auto. They've got a laser alignment machine and got it to the specs I wanted.
lucmor444
Re: Barton's NA6
Postby lucmor444 » Tue Dec 24, 2019 5:39 pm
Thx
bartmanftw
Re: Barton's NA6
Postby bartmanftw » Sun Feb 09, 2020 3:04 pm
Finally had a bit of free time so finished off my ms3pro adapter...well amost. It still needs a case for the adapter board.
I bought various wire colours in the sizes I needed to make it easier to identify circuits. There's still duplicates however it's still better than having them all the same colour.
I had a bit of 'help' cutting and crimping.
Hopefully will fit neatly under the passenger kick panel. The extra connector is to supply power to the wideband as well as CAN communication.
lucmor444
Re: Barton's NA6
Postby lucmor444 » Sun Feb 09, 2020 7:45 pm
That's very neat.
beavis
Re: Barton's NA6
Postby beavis » Tue Feb 11, 2020 2:12 pm
I agree, that looks lovely.
What's now stopping you from getting this installed and running?
bartmanftw
Re: Barton's NA6
Postby bartmanftw » Tue Feb 11, 2020 3:02 pm
beavis wrote:I agree, that looks lovely.
Not much. It will plug right in however I am using a third extra connector on my current ECU so I need to move all those circuits into empty cavities in the OEM ECU connectors. Only 10 circuits so won't take too long to do.
MX5NBpsi
Re: Barton's NA6
Postby MX5NBpsi » Wed Feb 12, 2020 1:13 pm
Its very neat as per usual.whats the reason for the MAF why not use MAP sensors like the rest of us plebs?
:NB8B: [SLOMX5]
Users browsing this forum: No registered users and 42 guests
