About 25 years ago I did a introductory welding course at TAFE in the evening. They taught you just enough to successfully weld a little with each process. From memory, it started off with Oxy-acetylene, then stick, then MIG, some brazing and finally TIG. I think it was the opening unit that someone would need to do as part of their trade apprenticeship training. I was never planning to be a boiler maker and but it was enough for a taste.
Soon after this, I bought an Italian SIP brand MIG and an old rusty G60 Patrol. Fixing it was pretty straight forward, as most of the panels were single skin and flat. Later, I picked up a very rusty 60 Series Landcruiser that also had tin worm. I found a body with the sections I needed at a wrecker, and the rest was a lot of measuring, cutting and welding.
I have never forgotten the clean magic of that TIG welder at the TAFE, and since getting more motorsport oriented things, I have always wanted to play with one.
I'm going to need a bit of practice, but finally the practice has begun.
